Closed Thread
Results 1 to 3 of 3
Thread: Pool bottom
    Dec 2005
    Denham Springs, Louisiana, USA.
    Question Pool bottom
    I am having an 18x36 inground vinyl diving pool installed. Three days ago the contractor poured the pool crete, hung and began filling the pool with water. The pool was full about 2 1/2 days later. My question is when we turned the light on the pool last night. You could see a lot of impressions on the pool floor in the shallow end of the pool. Is this normal at this stage. And will the bottom of the pool smooth out at all?
    Casey
    duraleigh Guest
    Default
    Hi, Casey,
    No, it won't get better....it's the nature of the beast. They make it intentionally soft so it will give if it's struck by a hard object. I have little heel indentions in my shallow end and they will only continue to accumulate. Your builder should've told you to plan on it to ward of any concerns. Sorry
    Dave S.
    Dec 2005
    Default
    Thank you for the info.
Closed Thread
