Thread: Pool Pressure Drops about 5 PSI - when valve set to full Main Drain
    Apr 2012
    New York
    Default Pool Pressure Drops about 5 PSI - when valve set to full Main Drain
    Hello - I'm curious if anyone has any thoughts on this - I've noticed that when I set my valve to full main drain, the filter drops about 4 or 5 PSI to around 14PSI. Normal filter pressure when on full skimmer or a balance between skimmer and main drain is about 20PSI. Does this indicate a leak with the main drain pipe back to the pump ? Thank you in advance
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pool Pressure Drops about 5 PSI - when valve set to full Main Drain
    Probably just indicates that the main drain line has more head loss than the skimmer which is not unusual at all. Probably a longer run and maybe smaller pipe.
    You want most of the flow from the skimmer anyway because it removes debris from the surface. MDs don't do much at all.
    Mark
    Apr 2012
    New York
    Thanks for the reply - both good points It would be a single pipe as opposed to two and it's definitely a longer run.
