Re: Cloudy blue, am I on the right track?
Wow!
I AM impressed! You have nailed EXACTLY what you need to do--and how much to add!
You can use the DE or not--you'll be backwashing alot and go through it, but you don't need much DE each time--I think it's a good idea.
But here's more: You need to keep adding the chlorine to maintain that 15ppm level. You need to check 2 to 3x each day--and right now I'd check 3x, adding more bleach as needed (you've got the amounts nailed!)
You need to run the filter 24/7, brush and vacuum (to waste) everyday.
If your test kit only goes to 5ppm, do a search on the entire forum for the CarlD Shot Glass method, or just shot glass method for how to read as high as 15 or 20 with your kit.
You need two more things: Patience and persistence.
First post and right on target! Congratulations and welcome!
