Do you use chlorine pucks in the skimmer? I don't believe I got a black grease ring until I started putting pucks in the skimmer while I was away from home. I just thought it was something in the pucks that was causing it?????
I use 3 inch pucks in my autochlorinator feeder, nothing in the skimmer. Sounds like this may be a "normal" thing. I'm just wondering what causes it, or what it may be?
I get the same thing around the waterline in 2 corners of my pool every winter (my pool stays open year-round)--I think it's probably just buildup of sunscreen, tanning oil, etc--but in the spring I wipe it off with a kitchen sponge, and it normally doesn't come back until the next fall.
There is a little sponge like thing called a 'scumbug'. http://www.rola-chem.com/scumbug.html
drop on in your skimmer and it collects all that stuff. Once it gets dirty just turn it over and when the other side gets dirty rinse it out and it's good to go again. They last about a season and also work really good just floating in hot tubs also. Been using them for many years now starting with my old portable hot tub (before I even had a pool) and now have one in my skimmer basket along with a skimmer sock. They only cost about 6 bucks and really absorb all the stuff that just seems to sit on the surface of the water before it collects on the tile line or around the skimmer!
Thanks for the info on the scumbug, I'll definitely pick up one on them. Half awake this morning, thought it was a scumbag......if that was the case, I could just drop a lawyer in my skimmer.....LOL !!!!!
Now THAT would definitely pollute the pool water!!!!!Originally Posted by pool newby
You want to remove the scum...not add more!
I use scumbugs in my Softub, didn't think I would need them in the pool, but I guess we do. I don't use pucks, just SWG and bleach to shock (on rare occasions).
