Results 1 to 10 of 15
Thread: Does CYA 'degrade' at any sort of average rate?
    Default Re: Does CYA 'degrade' at any sort of average rate?
    Cleaning the filter can make you lose your cya if you have recently added it. But, really, after about a week or so, the cya should have all dissolved and from then on, cleaning the filter should have no effect on cya levels.
    As a side note, trichlor is probably more successful with sand filters because the constant backwashing keeps diluting the pool and the cya level doesn't rise as fast. With a cartridge filter and trichlor it can only be a matter of months before the cya is way too high. I have personally seen these trends in the testing histories of the customers at the pool store I work at.
    Central FL
    Quote Originally Posted by waterbear
    That's good information to know. My husband used to use trichlor a lot during our first pool season (2 years ago). I found some old printouts from the pool store the other day, and our CYA was ALWAYS high...like around 90-100ppm.
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    About backwashing and losing CYA, just do what has been recommended here and add it to a sock or panty hose. I do this and tie it to the ladder in the deep end of my pool, in front of a jet. It usually takes about a week for it to fully dissolve. This way, you can backwash as often as you wish and it doesn't diminish your CYA.
