Thread: Maintaining Cl level while away from home w/o chlorine pucks
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: Maintaining Cl level while away from home w/o chlorine pucks
    There are options, and it is usually OK to swim in higher chlorine levels, depending on how high you go. You probably know how much chlorine you lose each day, and if no one swims in it and it is covered, you will probably lose half that, so plan accordingly for the number of days you are gone. If someone is going to swim in it, have them pour in some bleach when they are done.
    You could also add some polyquat algaecide before you leave, do some research on this forum on how to use that.
    Other options include installing a SWCG since you seem to be gone a lot in the summer, or some other form of chlorine injection system (beyond my scope).
    Lastly, using pucks is not bad, and probably your best option for your situation. You know it will add CYA, so you can deal with that as you need to, but you know your pool will be sanitary while you are gone and other people are swimming in it.
    Jul 2013
    Northern Illinois
    Have you considered teaching your friends how to test your pool while you are away? They could add what's needed, after checking with you, and enjoy the pool! I have done that and the friends were more than happy to learn. They also water my plants while they're at it!
    Mar 2012
    Yes. Actually trained our son last year. Will re-train him again this year and perhaps my neighbor. Thanks for the suggestion.
    In-ground rectangle 18x36 vinyl, 26,000 gallons, Hayward super pump, 1/2 HP motor, Hayward Sand Filter, Hayward Navigator Cleaner, Gas Heater (valved off now), county water system same as house, Atlanta, Ga area
    Jul 2013
    Northern Illinois
    You're welcome. Have to ask... Where are you going?
