Results 11 to 16 of 16
Thread: opening my green pool...UGH
    Jul 2013
    Northern Illinois
    Default Re: opening my green pool...UGH
    Do you use skimmer socks? They will help catch a lot of the pollen, (and other crud), before it reaches the filter.
    Scottsdale, Arizona
    I stopped using the water/acid mix to clean my cell. I feel it deteriorates them faster. I just use a wood paint stir stick to work between the plates and knock off the build up.
    Virginia
    Quote Originally Posted by Phillbo View Post
    That is my understanding as well. The owners manual for my SWCG says to use wood to remove scale unless it's real bad.
    Jun 2013
    Wow...that's good to know. I haven't cleaned mine yet so I will try that when it needs it. The water is beautiful and clean...only took 5 days. Now I am dealing with the filter...fiberglass sand. I think we will have to replace it...a small amount of water is seeping through the fiberglass...always something.
    PF=5; 23K gal IG kidney vinyl pool, Triton II Sand Filter, Whisperflow VS Pump, Taylor 2006 kit, Jacuzzi/Carvin Saniclear 40 SWCG
    Jul 2013
    Northern Illinois
    Hey, 5! How's the pool doing?
  6. #16
    Jun 2013
    The pool looks GREAT thanks to all of the good tips on cleaning it up. I was shocked at how quickly it changed to beautiful blue with balance of water and bleach...one week. I think when I started it up and the pressure was out of wack it caused the filter to leak the water. I know this will be the last season before we need to replace that. It isn't leaking now, but I have been running it on low. I'll keep an eye on it and hopefully it will make it through the season.
    Thanks again for all of the help!!!
  1. Opening a green, DE filtered pool (sigh)
    By ChuckD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-06-2015, 02:04 AM
  2. Opening pool to green algae
    By amillionpets in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-15-2014, 04:18 PM
  3. the old opening with a green pool
    By mikemedic in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-02-2006, 04:53 PM
  4. Pool opening-what is the best way to get rid of the green
    By 14me2 in forum Dealing with Algae & Slime
    Last Post: 04-19-2006, 02:04 AM
