Thread: brown stain is it rebar rust?
    y0manda is offline Registered+ Thread Analyst y0manda 0
    Default brown stain is it rebar rust?
    Noticed the first couple days after my new pool was finally filled a few stains in the pool. After reading this forum I was more concerned and had my water tested for metals which was 0. I got one of those erasers from Leslie's and rubbing lightly on my new black bottom plaster seemed to remove it although it did leave a mark on the plaster. There are a couple more about a dime size and one of the more darker one looks like its missing plaster about a BB size in diameter and about the thickness of a DVD if that. I didnt want to rub it with the eraser not knowing what further damage it may cause so I have been monitoring it for the past week now. Salt is goign to be added in a few weeks.
    Sanford, FL
    Default Re: brown stain is it rebar rust?
    Is this a new pool? Have you talked with your pool builder to see what they say?
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    actually I am the owner builder, and yes the pool is new about 2 weeks worth of water now.
    Sanford, FL
    Have you asked the company who did the plaster? The reason I ask is that you don't want to do anything that will void the warranty.
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
    No I am just waiting or monitoring the stains, There are still just the two small stains about a dime size if that. not getting any worse. Though I should call them to take a look at it.
  1. Rust stain on bottom of pool
    By OEMom in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-16-2011, 12:45 AM
  2. Rust stain on vinyl
    By msjulian in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-31-2008, 01:04 PM
  3. Rust Stain on Liner
    By rilesworld in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-07-2007, 09:56 PM
  4. SWG causes rebar stain
    By Crystal Clear Pools in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2006, 06:05 PM
  5. Rust Stain on New Plaster
    By md_rider in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-24-2006, 08:13 AM
