repipe?
hello,
I noticed I had some leaks at the front of the pvc piece going into the basket and the line going to the filter. This was causing air to show up in the basket. Is there a way to seal the leak at the fitting where it screws into the pump basket? I really don't want to cut apart and redo the whole thing and replace the valve because of the way its all glued together. thanks for any advice. Randy
p.s.
how would I attach a picture in here so people could see it?
- You may not post replies
- You may not edit your posts
Forum Rules
