Great Chart. I will retest FC in the morning as well as CYA. Thanks
Free Chlorine held steady overnight at 16PPM - but I did add some fresh water yesterday, not much and my automatic chlorinator is set to 1. Not sure how that skewed my results. Either way though, no significant drop at all, if anything it might have been a tad higher.
CYA Test showed 75 PPM
So according to the chart you provided I'm between the light green and orange - I'm guessing probably not good for long term exposure?
Is your water super-clear? If so, you can let your FC drop on its own. I would seriously consider removing the pucks from the chlorinator, or at least not adding more. The pucks will just add more CYA to your pool and you are already pretty high.
I was thinking about that, but I'm not sure what to do with them ? They're all soaking wet ... Maybe I'll just toss them in a sealed bucket until the FC comes down.
I pulled them out - the water is clear. Thank you for your help !
You're welcome! I would let the pucks dry out and then store them until you go on vacation and need to add some FC while you are gone. If you store them wet, they will break down to goo.
