Results 1 to 8 of 8
Thread: I think I've got a Leak, but where???
    May 2014
    Sussex, WI
    Default I think I've got a Leak, but where???
    Hi all, I opened my pool a week ago with no issues. Yesterday, I thought the water level looked a little low, but chalked it up to the frequent back washes. This morning, however, I'm sure something is wrong. I turned on the pump manually and was greeted with a lot of air blasting out of the returns for about 15 seconds. Everything went back to normal after that. The water level is about 1/4 inch below yesterdays even with about the same amount of rain. I'm guessing something in a skimmer line has cracked. Is there anywhere else I should look?
    25k gal pool, 18 x 36, 3' to 8' depth. Vinyl lined. Single speed pump
    Jul 2013
    Northern Illinois
    Default Re: I think I've got a Leak, but where???
    First off, did you add water back up to mid-skimmer level?
    26K gal 20x40 rectangular IG vinyl pool; Apr 2014: New pump, liner, auto-cover, & water; Pentair Whisperflo 1HP pump; Pentair Trition sand filter; Cover/Star CS-500 auto cover; Taylor K-2006C; OTO
    May 2014
    Sussex, WI
    Definitely! I've been very watchful of the water level because of the frequent back washes. As an added note, I keep a piece of black tape on one of my skimmers for a very visible reference of the water level.
    Jul 2013
    Northern Illinois
    Are you set-up with a main drain so you can close off the skimmers? If so, you could let the water level lower and see where it stops. The leak would be there.
    Do you see any water around the equipment?
    May 2014
    Sussex, WI
    No water around the equipment. I'll give your suggestion a try. I just hope the leak isn't in the main drain.
    Jul 2013
    Northern Illinois
    Let's hope not! Let us know what you find.
