MANY THANKS to POOL SOLUTIONS !
I simply wanted to take a minute and write THANKS to this site for the excellent advice and helps given in my situation.
I had used Tri-Chlor pucks in the past without paying much attention to the CYA levels and it ended up in a bad situation when I opened my pool this year. After killing off all the algae I had very high levels of CC which took large quantities of Chlorine to finally get resolved.
I also ran out of testing solutions and Ben graciously rushed a PS234 kit in order to help me.
After paying close attention to the problem, reading these forums, and using my test kit, I now have a beautiful swimming pool again with zero CC, and all of the other parameters are where they should be.
The PS234 kit, and understanding the nature of the problem as described in these forums, was absolutely essential in getting this resolved.
So THANKS SO MUCH FOR EVERYTHING !
AND, after trying the BBB method, my pool is sparkling clear and it feels great to swim in.
So, pardon the rant, or should I say praise in this case.. but I'm grateful for the site and the advice of so many.. You folks are doing a great service to those of us who need to get a handle on the seemingly underestimated complexity of water chemistry.
Mark in MA.
Re: MANY THANKS to POOL SOLUTIONS !
So happy to hear everything is working out good for you. I don't think I pitched in on your particular problem, but it sure is nice to have it all running right once you understand it, eh? Makes having a pool a pleasure again!
Michael
I'll go along with that too - thanks to the moderators and frequent flyers on the forum that made getting a new pool up and running a very smooth and easy process. I'm happy to return the favor by passing on the things I've learned to others on the forum whenever possible.
Peter
- You may not post replies
- You may not edit your posts
Forum Rules
