Re: Very Green Cloudy Pool
What kind of pool? Post a full set of test numbers, from a pool store if you have to go that route.
If it turned green again after you got it blue, you either let the chlorine drop or have copper in the water. To defeat algae, you have to add chlorine several times a day in many cases. You have to test, and test accurately to know how much to add.
While waiting on good numbers, maintain your chlorine level and filter 24/7. Brush the pool daily, and vacuum to waste if possible.
