Results 1 to 10 of 13
Thread: Leak- Losing 3" a day
    Default Re: Leak- Losing 3" a day
    Yes, I fear it is the main drain that is leaking.
    I plugged all the returns in pool and spa. (The water level was already below the skimmers) and the level went down another couple inches over night.
    Is the main drain a major repair? What is involved in the repair? Do I have to drain all the water out of the pool?
    Honesdale PA
    Someone else can chime in because I have no idea. Anything buried can be a real PITA, translated...$$$$. Personally I wouldn't want one. I'd still do a dye test just to confirm.
    So.. I am losing waaaay more than 3" a day. I lost over 12" in the last 24 hours. The water is now 1/2 way down the light.
    I am letting the water go down to see if it will stop after the light, and if not guess its the main drain. I guess I wouldn't be losing this much if it was the light.
    I did the dye test around the light and nothing. I tried to do it on the main drain, but I need to get a longer pipe. My wasn't long enough to get close.
    Default Re: Leak- Losing 8" a day
    I had a pool guy out today.
    He said I am losing water so fast (8-12" /day) he thinks that the hydrostatic plug rather than a leak in a pipe/drain. My water level is down about 4 feet. He thinks the hydrostatic plug may be stuck open that a normal leak wouldn't be so fast. He also said main drain leaks are usually as low as mine has gone.
    Does this make sense as a possiblity?
    Jun 2010
    NY state
    Hi ellry99,
    It's been 5 years since your last post, but would you mind posting an update on how you resolved your leak problem? My pool is leaking the same way yours did, and I was hoping to get some pointers. Thanks!
