No, the pressure doesnt drop after putting in clean filter. No, i havent tried turning off the main drain. Im heading out now to mess with it. I'll do that and see what happens. Thanks
If your experimenting shows that there is a blockage in the skimmer, you could put a garden hose in the pump basket into the skimmer line and see what happens. If there is a blockage, it may push it back into the pool if you have enough water pressure.
Hi JenniferC, It sounds like the filter cartridge is clogged by the phosfree as you suspect. Can remove the cartridge and just run without it to test flow and the gauge pressure?
I know some people run with high phosphates and it works for them providing the free chlorine level is maintained at the correct level for your stabiliser level, did the pool shop disclose all the figures for you? Personally I prefer to reduce the phosphates so the pool doesn't go green in the blink of an eye if the chlorine tank runs out but others in the US don't and run successfully.
