Thread: Help me decide between these two pumps
    Toronto, Canada.
    Default Help me decide between these two pumps
    I have a 13000 gal pool with one skimmer, no drain and 1.5 inch pipes.
    I've narrowed it down to these two:
    WhisperFlo
    model: WF-23 STANDARD MOTOR
    3/4 HP Up-rated
    SF 1.3
    115V, 10.5 Amps
    OR
    Hayward Super II
    model: SP3005X7A STANDARD MOTOR
    3/4 HP Up-rated
    SF 1.0
    115V, 11 Amps
    The WhisperFlo is $75 more than the Hayward. Which one should I get and why?
    Thank you for your help.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Help me decide between these two pumps
    The WhisperFlo has more braking HP (BHP = HP *SF) for less current. This means it is a more efficient pump and GPM/KWH is higher than the Hayward so I would vote for the WhisperFlo.
    However, the most efficient pumps I have seen are the Hayward Northstar line of pumps. The 3/4 HP has a service factor of 1.85 and draws 11 Amps @ 115v. The highest BHP for the current and one of the best GPM/KWH. This pump will turnover the pool faster than the Wisperflow with about the same current.
    Mark
