Thread: Frog leap system
    Apr 2018
    WISCONSIN
    Default Frog leap system
    I recently purchased a new 18 X 52 above ground pool, it came with a frog leap system. I am seeing much positive and much negative with this particular system. I am new to pool maintenance and am not really sure how to go about having safe and clean water, years ago when I was young our family had a pool but my father just poured bleach in it..... We live in Wisconsin if that makes a difference in maintenance, any tips on how to use this system effectively since I already have it ? I am not so much concerned about cost, just safe clean water hopefully with no green hair or brown stains on a new pool linner. Oh I should add that we have a cartridge style filter, not a sand filter.
    Default Re: Frog leap system
    Upgraded membership to *General*.
    Moved thread to "Testing and Adjusting Pool Water Chemistry".
    Quick answer:
    Your dad's plan was almost certainly better than the "Frog Leap" system. Virtually all such systems cost you more $$$'s and make a mess in the end. "Frog" systems are copper based, and may work for you if
    • You don't mind stains;
    • You don't mind green hair OR, if everyone in your family has dark hair;
    • You are mostly concerned with algae, and don't let non-family members (and non-family GERMS) in your pool very often.
    Read the stickies, if you want to know more.
  1. Frog System
    By Mr Bill in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-15-2006, 03:42 PM
  2. Frog System/New Pool
    By thelma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-18-2006, 07:17 AM
