Results 1 to 10 of 18
Thread: Best Shock for Algae
    Jul 2013
    Oklahoma
    Default Best Shock for Algae
    Hi, I am new to the forum and have been searching to see if there is a post that shows what brand of chemicals everyone prefers. The only pool supply store I am near carries Bioguard. But, I don't mind shopping on Amazon. I need a good shock for algae.
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: Best Shock for Algae
    Chlorine in the form of good 'ol bleach. "Shock" just means you bring your chlorine in the pool up to a level that will kill an algae bloom, usually up to 20-25% of your CYA or stabilizer level. You can buy bleach from any store, for me the cheapest is walmart brand regular bleach, costs about $2.90 for 121 oz (not quite a gallon). Even cheaper is the Pool Essentials chlorine at $2.50 in the pool section of walmart, and it is more concentrated. Some people on this forum get chlorine elsewhere, it depends on where you live. I have checked with my local pool store and their chlorine is way too expensive. The only thing I buy at my local pools store is Taylor testing reagents and PVC parts for my pool brand, and even then I can usually find it cheaper online.
    Jul 2013
    Oklahoma
    Thanks! I guess I need to educate myself a bit more on chemicals. I assumed "shock" purchased from the pool store had something else in it!
    Anonymous [GDPR] European in the UK Guest
    Quote Originally Posted by spatt View Post
    Now you mention it, yes it has. Usually more cyanuric acid stabiliser, A lot of pools get into trouble through being over stabilised so adding bleach removes that issue.
    Very powerful shock (HTH brand etc are calcium hypochlorite) this doesn't contain stabiliser but is usually more expensive than bleach and can add even more calcium hardness.
    That means bleach is the way to go!
    May 2014
    Your welcome! You can learn a lot by browsing around this forum or the sister site Pool Solutions.
    Jul 2013
    Oklahoma
    Thank you both. I didn't get much education when we had the pool installed 3 years ago. Just a pentair test kit, chlorine tabs, baking soda, muratic acid and a huge bill. The pentair test kit seemed fine until I developed some sort of algae a few weeks ago. It actually looked like a rust stain at first then morphed into what looked like a clot of dirt stuck to the bottom then it started spreading. I am assuming it's black algae but the color is still rust so maybe mustard algae. So, I headed to the only pool store in my town and they had me shock it and add an algae killer which did nothing except cause my pool to foam and develop a weird green film on the water line of my filter baskets. We have brushed, scraped and rubbed with a chlorine tablet but nothing has changed. So, after reading a few posts her I decided maybe I better order a different test kit and see what is really going on with my water. Until I get the Taylor K2006 kit that I ordered I don't feel comfortable dumping bleach in because my current test kit only goes to 3.0. I have never tested anything other than chlorine, PH and alkalinity. I am confused about all the other tests mentioned in posts. Hopefully, after doing some additional research on the boards I will be able to find out what else I need to be doing!
    May 2014
    Maybe we can get started now rather than wait for your taylor kit and your pool is a disaster.
    1. Get an HTH 6-way test kit from Walmart, if you can. You can test everything fairly accurately and use the reagents for daily testing of chlorine, its cheaper than the taylor drop test but is certainly not as accurate. Test your pool TODAY and post all the results.
    2. List your pool specs: vinyl or not, size, fill water source, pump and filter set-up, temp, etc.
    3. What's in your pool now? what did the pool store have you put in and how much?
    4. My guess is you need to stop using the pucks (tabs) for now, and use only chlorine in the form of bleach. I am betting your stabilizer (CYA) level has gotten way too high.
    Once you post the above we can help you along, but don't wait too long or you will have much more work to do, and summer is almost over.
    Jul 2013
    Oklahoma
    Well, I doubted my little Wal-Mart was going to have the HTH kit but they did!
    I have run the tests and here are the results. Also, I updated my signature line with my pool specs.
    Temp - 86
    TC - looks a little greater than 5 ppm but the test didn't go any higher.
    PH - 7.6
    CYA - 80 ppm
    ALK - 120 ppm
    Hardness - 700
    Doesn't that all look pretty good other than the chlorine and the hardness?
    Honestly, I need to get a picture of the "algae". I had a pool guy look at it and he couldn't tell what it was.
    I went to my local pool store and followed his directions. I shocked it two weeks ago with bioguard 3 and immediately followed with bioguard banish. I brushed before and after for several days. After a week I cleaned my filter cartridges. I saw no results other than foam on the top of my pool the next day.
    Then I was able to go to Leslie's (after reading the forum, I wish I hadn't) and was told to use their Black Algae killer. I added it per the bottles instructions on Thursday last week and brushed. I waited to wash my filter cartridges. Again I saw no difference. The pool foamed again and a green gunk stuck on the water line around the pool. I'm still struggling to get that all cleaned off.
    Lastly, my husband got into the pool with a chlorine puck and scrubbed each spot but I still see no difference. And, it's not spreading quickly either. It has stopped where it is so maybe thats progress. Or maybe it's just a stinkin stain and I cant tell (insert hair pulling emoji here)
    Thank you for your time - I really appreciate it!
    25K gal 17'x40' freeform gunite pool with spa built Nov 2013. Paramount in floor cleaning system, paramount clear 03 system, Jandy cartridge filter
    May 2014
    Sounds like a beautiful pool! Yes, your numbers look good for now. One question you didn't answer is what do you usually use in your pool?
    Don't put anything in your pool right now but chlorine in the form of bleach. If you the label of regular bleach and the Pool Essentials chlorinating liquid in the pool isle at Walmart, they are the exact same substance. Don't get rid mof the tablets, they will be useful, they have chlorine, cya and calcium. You don't need any more cya or calcium.
    A good rule is to only put in your pool what it needs. Read up on the BBB method here and at Pool solutions, I can't explain it as well as Ben and the other mods did back when this forum was in its prime.
    Then first thing to do is to get your chlorine up to shock level. If your test kit is still yellowish and not orange, we can add some bleach safely. According to the best guess chart, your shock level is 20+ppm. 1 bottle of bleach at 8.25% will add approx. 4 ppm FC to the pool, the Pool Essentials chlorine will add a little over 5 ppm.I feel comfortable adding at least 2 bottles, that should get us close to 20 ppm.
    After that, brush your pool every day, vacuum and backwash as needed. Other than that, we'll have to wait for your new test kit and see how it goes. Let Mme know!
    Jul 2013
    Oklahoma
    I have been using the 3" chlorine tabs from Leslie's.
    I am out of town until this evening. I will add the bleach when I get home. Which, after reading this forum is better anyway. Are the metal brushes better? I'm terrified they may be to abrasive?
    When should I retest?
