Thread: "Simple Chart" to Post in my Pool Shed.
    Default "Simple Chart" to Post in my Pool Shed.
    Is there a simple chart out there, meaning a chart that defines each chemical and its use, along with ppm's that should be obtained. Included maybe a chart for entering your results. Since I am new to this, and forget all this stuff real quick, I would like to hang a chart in my shed to keep me understanding this stuff.
    Mike
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    Default Re: "Simple Chart" to Post in my Pool Shed.
    Mike,
    In Ben's new kit, he sends charts with them. If you haven't ordered one yet, you should go ahead and get it. There is a best guess CYA chart that shows what PPM to keep your chlorine levels and also what levels are needed to shock, CYA is from 30-50, but there are folks that run it a lot higher than that, so it is a subjective number, PH around 7.5, ALK I think is around 100-120, not sure on CAL since I have a vinyl liner and don't need to test for it. I hope I am right on these as this is coming off the top of my head. You can search the test kit results threads and see what numbers are posted and what the experts recommend doing. With this theory on pool maintenance, you need Bleach, Borax, & Baking soda-BBB, also muratic acid and CYA. Pretty basic, very simple and effective, both results wise, and from someone like myself that switched from Baquacil, cost wise. Good luck!
