We bought a 24’ 48” marquis. I plan on using the BBB method. Any tips or tricks to master this? Any must haves for the pool? I bought a tester kit and skimmer socks
I assume the pool is filled?
- 24' x 48 => 11,800 gallons (unless the bottom is dished). PF=10.1
- 1 gallon of PLAIN (no flavor, no gel, no scent) 6% bleach will add (0.5 x 10.1) ppm of chlorine or ~5 ppm)
- 1 gallon of 10% pool bleach will add (0.85 x 10.1) ppm of chlorine or ~ 9 ppm.
- pH UP adjustment dose = 1 cup measure of borax
- pH DOWN adjustment dose = 1/2 cup measure of muriatic acid
So . . .
If you can find this HTH 6-way at Walmart, get one. Otherwise order one from Amazon. (Yes, you'll want both).
While you are at Walmart, buy:
- 1x box 20-Mule-Team-Borax
- 2x gallons Pool-Essentials-Chlorinating-Liquid OR
- 4x gallons Great-Value-Cleaning-Bleach-128-fl.oz.
- 1x HTH-6-Way-Test-Kit
Test your pool in the EVENING. Make SURE the pump is OPERATING.
- If chlorine level is below 2 ppm, add 1 gallon of bleach or 1/2 gallon of pool bleach.
- If pH is below 7.2, scatter 1 cup measure of borax in the pool.
- If the pH is above 7.8, you will need some acid from Lowes or Home Depot. Read the "Using muriatic acid" article linked in my blue signature.
- Report results and actions in THIS thread.
- ALSO, list any chemicals that have ALREADY been added.
Good luck!
[ Membership upgraded; thread move to pool startup section; you made need to log out and back in to see everything; posts are STILL moderated before appearing.]
PoolDoc / Ben
PS. If you got a salt system with the pool, take it back if at all possible. No matter what you're told, salt systems will DESTROY AG pools!
