Closed Thread
Thread: Still cloudy
    Fort Worth, Texas
    Default Still cloudy
    I have kept my cl at 20+ (up to 30+ per duraleigh) for several days now.
    The green is gone, and I continue to have a milky blue pool.
    At this rate, it could be October before my li'l cartridge filter knocks out all of the cloudiness.
    My pH has consistently tested at 7.0. Should I raise it? I read that pH readings could be off when running super high cl levels.
    If I need to raise it, do I use Borax? How much?
    Thanks.
    B Gray
    28,000 gallon IG gunite pool
    Pentair cartridge filter
    Fort Worth, TX
    duraleigh Guest
    Default Re: Still cloudy
    bgray, when you start a new thread no one can see the history of your posts. Keep everything in one spot.
    I'll reply to this one in your other thread.
    Dave's absolutely right: Do not start new threads on the same topic. Consider this one closed.
Closed Thread
