Re: New to AGP's
MOST of the work involves the ground prep, which is the MOST important part. If you don't see a problem getting a level and compact base, digging in the blocks, then the rest is just putting things together - It is a LOT of work either way but I believe 100% worth it.
We are just now filling our new 18x33 and had WAY more to do because the entire yard area had to be filled and compacted, edged, set for proper drainage, etc. instead of just leveling a spot for the pool (long story) If you just need to grade it level - have at it. Borrow or rent a transit - the best tool you can have for this job to be sure its all correct.
Don't know anything about the pool brand though - you may want to Google it, or find out who the actual manufacturer is and Google them. What is the warranty on it? That will tell you a lot about quality right there.
