Thread: Looking for simpler pool chemistry in Rochester, NY!
    May 2018
    New York
    Default Looking for simpler pool chemistry in Rochester, NY!
    Hi, I am new to the forum so I am always searching for good information. Last year, we moved into a house with an in-ground pool having come from a house where we installed an above-ground. This summer will be the second season using all of the new equipment I installed last year but I will be continuing to make modifications this year. I replaced the pump, all the plumbing and the filtration system shortly after we opened the pool last summer. While everything is working well, the chemistry is quite a bit more finicky than I am interested in keeping up with. More to come....
    Default Re: Looking for simpler pool chemistry in Rochester, NY!
    [ Upgraded membership; moved thread to chemistry problem section => you may need to log in and log out to gain access! ]
    Einstein apparently said something like, "When I'm teaching, I try to make everything as simple as
    possible, but no simpler."
    (The original was apparently in German, so versions of the quote vary.)
    That's my goal for the forum: as simple as possible, but no simpler.
    Expectations vary.
    For most pools, as simple as possible, for pool chemistry maintenance, translates into 1 hour per week AFTER purchasing K1000 and K2006 testkits (Amazon link in my signature) learning to use them, and learning to dose the pool (10 - 20 hours it seems). Does that meet your expectations?
    If not, the only SIMPLER method is to hire a pool company. Unfortunately, most of them aren't very good, so you may NOT actually save time, and it WILL cost more.
