Thread: Will it affect my swimming pool warranty if I use bleach?
    May 2018
    Louisiana
    Default Will it affect my swimming pool warranty if I use bleach?
    Will bleach affect my pool warranty? Pool is green!!!
    Default Re: bleach and pool warranty?
    I could tell you that bleach wouldn't hurt your pool . . . but that's not relevant: pool warranties are often written by people clueless about pool chemistry. I've seen warranties that REQUIRED damaging pool chemistry!
    In general, pool equipment manufacturers are fairly clueless about pool chemistry. The only way to tell what's in the warranty is to read it, and the only way to tell how it would be interpreted is to ask the company offering the warranty.
    On the other hand . . . how would they know, if you used bleach?
    Upgraded membership; moved thread to chemistry problem section => you may need to log in and log out to gain access!
  1. Does 33 degree Pool Water affect testing results?
    By let_her_flicker in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 11-26-2014, 01:30 AM
  2. Can plain household bleach be used as a swimming pool sanitizer
    By stevenh496 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-27-2013, 03:13 PM
  3. Problems with Wilkes Pool Warranty - 15 x 24 Genesis Pool Collapsed
    By amlynch1128 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-16-2013, 03:39 PM
  4. Which pool robot has the best service, reliability and warranty?
    By titaniummd in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-21-2013, 01:12 AM
  5. Bleach's affect on Alk?
    By Rangeball in forum Dealing with Alkalinity and Calcium
    Last Post: 06-19-2006, 01:38 PM
