Thread: What causes damage to copper heat exchanger in pool heaters?
    May 2018
    Seven Springs, NC
    Default What causes damage to copper heat exchanger in pool heaters?
    Has anyone had any problems using a gas heater with a copper heat exchanger. I'm keeping the chemistry right (pH usually 7.4-7.8) and do not want to have a copper problem in my pool water.
    Default Re: What causes damage to copper heat exchanger in pool heaters?
    Problems with heat exchangers are common, typically for any of three reasons:
    1. Failure to maintain overall pool chemistry -- mainly, pH > 7.0 .
    2. Adding acids via the skimmer. (Even though the OVERALL chemistry is OK, this can damage heaters)
    3. Trichlor in skimmer, or in feeder upstream of heater, or (with pump timer) NEAR the heater, even though downstream.
    Trichlor damage to heaters is VERY common, but usually occurs only on pool with pump timers. It is good general practice to set timers to have TWO 'on' periods, no matter what the total hours.
    Good luck!
    [ Upgraded membership; moved thread to pool equipment section => you may need to log in and log out to gain access! ]
