[ Upgraded membership; moved thread to pool repair section => you may need to log in and log out to gain access! ]
1. You should be able to post pictures using imgur.com. To get the full embed link you have to view the pics full size in Imgur, then right-click to capture the direct link. If they don't work, I'll grab them when I moderate your post in.
2. Once you get GOOD pics, you may want to cross-post TroubleFreePool and PoolSpaForum. None of the pool forums have many active posters actually in the pool biz . . . especially this time of year. And DIY advice is likely to be low in quality. Do add a note about cross-posting and indicate you'll close out the other threads once one goes usefully active.
3. Unless you are planning on hiring a contractor, explain your DIY capabilities. For example, some tells you to cut out the deck to access the skimmer . . . and you have no idea how to do such a thing, everyone has wasted time.
4. NO idea at all what you mean by "broke off a skimmer" in an IG pool . . .
