Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 58
Thread: Upgrade recommendations for replacing 14" Intex sand filter combo?
    May 2014
    Plano, TX
    Default Upgrade recommendations for replacing 14" Intex sand filter combo?
    My 14" Intex sand filter is beginning to spit sand into the pool. I don't really want to just repair or replace it with another Intex, so I'm thinking about a "real" pump/filter combo. The pool is only about 4500 gallons, so I probably need the smallest pump available, a two speed might be nice. I might also consider keeping the pump until it dies and only replace the filter for now. The system I have now is Intex model SF70110. Specs are - 120 VAC, 4.8 A, 30 psi max working pressure, 2150 gph max flow rate, 77 lbs silica sand.
    I am well aware that some "engineering" will be necessary to convert from Intex proprietary fittings. I am capable and willing.
    1. Should I really consider replacing the filter only?
    2. What size and brand?
    3. Is a 2-speed pump worth the extra cost on a system that small?
    4. Other considerations I haven't thought of?
    Default Re: Upgrade recommendations for replacing 14" Intex sand filter combo?
    The "Hayward S180T92S 18-Inch 1 HP Sand Filter System" looks like a good, complete option.
    I'd recommend several things:
    1. Amazon usually accepts returns on defectives very easily . . . but be READY to install, and check everything out, so you can return PROMPTLY if needed. Hayward is usually pretty good out of the box, so hopefully you won't need this.
    2. Get a timer to run with it. On a 15' pool, you will not need to run 24/7.
    3. Upgrading to 2-speed on your own opens a can of worms you probably don't want to get into, on a tiny system like this. And, with a timer, the savings won't be huge. (Hayward catalogs a 2spd version of this unit, but I couldn't find any for sale.)
    4. Get a valve you can throttle:
    1.5 Hayward Industrial threaded PVC ball valve
    1.5" PVC nipple
    The pump may have too much flow, especially on backwash.Throttling it will not only reduce flow, but will reduce electrical usage somewhat. If you do NOT throttle, you may lose sand each time your backwash, AND you may 'force' dirt through the filter during normal operation. If you throttle enough so you do NOT loose sand during backwash, you probably have throttled enough to get good filtration.
    CAUTION: do get the nipple. PVC ball valves can be 'stiff'; you'll need the strong nipple to 'turn against'. Put the nipple directly into the pump discharge port, and the valve on top of that. Also, ball valves trap water when open or closed. To winterize, leave the valve in a PARTLY open position.
    Good luck!
    May 2014
    Plano, TX
    Thanks! I looked at that and some Pentair equipment. It seemed like Pentair was more costly. Is it really that much better? Would this https://www.amazon.com/Hayward-SP175...Cp_36%3A-25000 coupled with a 16" or 18" filter be better than the 1hp 18" complete system? A few dollars extra for a better system is ok for me. The max flow on the .5 hp pump is 55 gpm, which is far above the max flow of even the 18" filter. How many gallons the .5 hp will push through a 16" or 18" filter? Would the .5 hp pump provide enough flow to properly backwash? Would I still need a throttle? Would it hurt anything to plump the 18" Hayward to my Intex pump? Seems to me the worst case would be it wouldn't flow enough to do the job.
    Probably because AG pump/filter sizing is so 'flaky', the manufacturers usually do not make it easy to 'engineer' an AG pump filter combo.
    Keep in mind, that the HP designations on AG pumps mean much, much less than you'd think: here's comparison table on the Hayward pumps:
    https://www.hayward-pool.com/shop/en...ix-a-supowm--1
    In general, bigger filters and smaller pumps are better. But, available equipment is better than unavailable equipment. A perfect match would probably be a 1 HP VS pump with a 21" filter, operating at 10 GPM for 8 hours per day, but backwashing at 12 - 15 GPM. However, such a system would probably cost $1,500 and have to be pieced together.
    Everything is a compromise; nothing is fully optimal. But, I'm pretty sure the system listed above will work well, if throttled, and will be pretty economical, both to buy and to operate. And . . . it's available and serviceable.
    May 2014
    Plano, TX
    I did know that relating the HP rating of centrifugal pumps to actual performance is kinda like voodoo. Performance depends on how the pump is designed, intended flow and pressures, and on and on. And none of them are tested, rated and reported the same way. As far as availability, the Hayward S180T 18" filter is available today from Amazon, as is the Hayward SP1750 .5 HP pump. I also am in possession of an Intex pump that is rated at .75 HP, 4.8 A and 35 GPM (depending on which Intex source you look at). All the Hayward stuff should be plenty serviceable, shouldn't it? If a 1HP variable pump works on a 21" filter, would a .5 or .75 HP not work with the 18"? I'm almost kinda sorta nearly leaning toward hooking the 18" filter up to my Intex pump, and seeing how it works. Then deciding if I can go smaller, need to stay about the same, or go bigger and throttle. But then, a complete system is cleaner, much more convenient and less expensive - equipment wise - in the long run.
    "a complete system is cleaner, much more convenient and less expensive - equipment wise - in the long run."
    . . . that was sorta my take on it . . . at least when the system is fairly competent, and that one seemed to be.
    May 2014
    Plano, TX
    One last question - I think. Is there any significant seasonal price difference in pump/filter equipment? End of season sales or the like? My problem isn't terrible and I could live with it till we close the pool for the winter. 10% savings is probably not worth the wait, 25% would be.
    Short answer? I don't know for sure, but I've never seen any evidence of that EXCEPT . . .
    There is some times clearance on 'leftovers', but that puts you in a mix-n-match situation that can be tricky to work out and difficult to warranty.
    Good luck!
    May 2014
    Plano, TX
    Since I like to tinker and "injuneer", and in the interest of keeping my darlin' wife a little happier, I've decided on this piece together system.
    https://www.amazon.com/Hayward-S180T...keywords=S180T
    and this pump
    https://www.amazon.com/gp/product/B0...G42D8KUC&psc=1
    I found some Hayward propaganda that claims the S180T "design flow" is 35 GPM. The
    SP1592 is rated at 58 GPM @ 40' of head pressure. I decided to go with the two speed model so maybe I won't need to throttle on low. The two speed will use less electricity on low than a throttled single speed, and I think it'll make less noise. This system will cost about 20% more than the complete single speed system, but I think the complete system probably comes with the LX series pump, instead of the Matrix.
    Is this valve
    http://www.amazon.com/exec/obidos/AS...AI2/poolbooks/
    any higher quality than this one?
    https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
    My experience has been that the Hayward pool valves are lower grade than the Hayward industrial valves.
    Will this make a practical difference to you? Dunno. What's going to matter is whether you can operate the valve. Larger ball valves can be 'stiff'. That's why I suggested the S-80 nipple as the attachment point, so you will have a firm strong connection to stand the torque of handle operation.
    One caution: AG filter "design flow" is bogus, and has been for years. Sand filter 'efficiency' at particle removal INCREASES as flow rates DECREASE. Inground pools are rated at 15 GPM per sft of sand filter area. Above ground pools are rated at 20 gpm. An 18" filter is rated at 26 GPM for an in-ground pool, but up to 35 for an above-ground pool. The lower rating on that filter is possibly that it has a shallower sand bed, which lowers the rating. Unfortunately, for good filtration you need to run at 12 gpm/sft, or 22 gpm.
    Why the difference? Just because . . . of marketing needs. There's no science or engineering behind it; filtration requirements on AG pools are actually MORE demanding than on IG pools.
    So, do what you like. But 58 gpm is more than TWICE the optimal flow through that filter. Low speed probably won't be enough to backwash, but on high, you'll likely lose sand every time. And if you ever turn it on 'high' when it's set to filter . . . you'll clean the sand right into the pool!
  1. Sand Master Soft Sided Above Ground Pool Sand Filter for 15'x48" Intex Metal Sided
    By ransomedbyfire in forum Pool Equipment & Operations
    Last Post: 07-16-2016, 04:36 AM
  2. wide mouth skimmer/sand filter upgrade
    By kdrennan122 in forum Pool Equipment & Operations
    Last Post: 05-28-2014, 12:30 AM
  3. Using a SuperFlo pump and a 24" sand filter on an Intex pool
    By The Diesel in forum Intex-type Pool Setup & Operations
    Last Post: 05-20-2014, 09:32 PM
  4. Intex combo sand filter SWCG question
    By rmk_racer in forum Intex-type Pool Setup & Operations
    Last Post: 06-15-2012, 11:05 PM
  5. suggest a good sand filter/pump model combo for 24' AG
    By ScottS in forum Above-Ground Pool Construction & Repair
    Last Post: 04-01-2007, 01:06 PM
