Thread: New 22' Coleman/Bestway pool in San Antonio
    May 2018
    TX
    Default New 22' Coleman/Bestway pool in San Antonio
    Just got me a new Coleman 22'x52" above ground pool... Looking forward to taking care of it...
    Default Re: New 22' Coleman/Bestway pool in San Antonio
    Welcome!
    Several cautions:
    1. If you got a saltwater system, do NOT use it. If you've added salt to you water, drain and refill. The Intex / Bestway / Coleman frames are NOT compatible with salt. They'll usually last a year, but not the 4 - 6 years Intex Ultra users often get otherwise.
    2. Coleman is a 'prostituted' brand-for-hire. You can't contact Coleman USA for support. Support is via Walmart or Bestway (lots of luck!)
    3. If you don't already have one, get a sand filter and matching pump. The cartridge filters will not work out well for you, unless you have 2 - 3 of them
    4. Probably 10 - 15% of Chinese made pools (Intex, etc) have defects. Check your pool out NOW and return it ASAP if needed. Warranty support after the initial !00% period is POOR. Take it back to Walmart for an exchange, if at all possible.
    But otherwise, these pools are often a GREAT deal, given good satisfaction and last a number of years . . . IF you do NOT use SALT!
    5. Get an HTH 6-way and use it. Get a K2006 later.
    Good luck . . .
  1. Bestway swimming pool
    By Amyjarusik977 in forum --cleanup--
    Last Post: 07-17-2016, 05:45 PM
  2. Replies: 0
    Last Post: 06-23-2016, 09:29 PM
  3. Coleman 14' x 42" pool
    By samanthafox9713 in forum --cleanup--
    Last Post: 06-06-2016, 04:21 PM
  4. Coleman above ground pool
    By Maryrtaylor in forum --cleanup--
    Last Post: 06-03-2015, 05:07 PM
  5. San Antonio Contractors
    By Marksatex in forum In-Ground Pool Construction and Repair
    Last Post: 06-06-2011, 11:08 PM
