Results 1 to 10 of 47
Thread: Too much DE in pool
    Jul 2011
    Los Angeles, CA
    Default Re: Too much DE in pool
    Right, yet there's a lot of DE in my pool, and it's been there for a while now. The pool clouds up as soon as I attempt to brush the algae off the steps and sides.
    It's a Purex/Pentair 36 sq. ft filter. I'm testing with strips, recommended by my neighbor and acquired from the experts at Home Depot. I didn't realize until today that they were no good.
    20,000 gallon plaster (concrete) pool
    DE filter
    Nature 2 (unchanged)
    Jul 2011
    Los Angeles, CA
    PS - everything I've been able to find online tells me that one of the surest ways to get DE back into your pool is to put too much into the filter.
    DE filter
    May 2014
    Plano, TX
    How much DE did you put in? If your pressure is running high, keep cleaning the filter and brushing. Eventually you'll filter out all the excess DE. If your pressure is running low, that means the DE - and lots of other stuff - is bypassing the filter grids. And all this has nothing to do with green.
    Jul 2011
    Los Angeles, CA
    It WAS running high. Now it's normal. But I still have all this DE in my pool.
    I believe it's a 2000 series filter.
    DE filter
    Jul 2011
    Los Angeles, CA
    Everything else checked out normal. Some DE at the bottom of the filter, most of it on the grids, which were new last year and have no holes.
    DE filter
    May 2014
    Plano, TX
    Okay. If you keep brushing and stirring up the DE where the filter can catch it, then cleaning when pressure gets high, you'll eventually get that issue cleaned up. If there's a walmart close to you that has the HTH 6Way pool test kit, get one and tell us what your chlorine, ph, and CYA levels are. Then someone can help with the green.
    Jul 2011
    Los Angeles, CA
    Alright. So no to the flocculant, then. You sure?
    DE filter
    Jul 2011
    Los Angeles, CA
    I've got a couple other test kits here. One's called Guardex; the other doesn't have a name. But the refills are from Home Depot.
    DE filter
    May 2014
    Plano, TX
    A lot of DE in your pool indicates your filter is malfunctioning for some reason. I would open the filter, and CLOSELY inspect all gaskets, o-rings, grids and connections. The fact that the issue started when you serviced the filter leads me to believe there is "probably" an easy fix issue. An out-of- place gasket or o-ring letting water bypass the filter or maybe a torn grid. When you cleaned the filter after the problem started, was there DE on the grids or in the bottom of the filter housing? Is your filter pressure normal? I'd bet it is running low. Do you know if your filter is a 2000-series or FNS - or something else.
