Results 1 to 10 of 47
Thread: Too much DE in pool
    Jul 2011
    Los Angeles, CA
    Default Re: Too much DE in pool
    I've got a couple other test kits here. One's called Guardex; the other doesn't have a name. But the refills are from Home Depot.
    20,000 gallon plaster (concrete) pool
    DE filter
    Nature 2 (unchanged)
    May 2014
    Plano, TX
    I'm absolutely certain that MOST of the time, the experts here, and I'm not one of them, advise against flocculants. That might clear the DE out of the pool quicker, but many flocculants contain other "stuff" that is bad for your pool and often introduce other issues that are much more difficult to correct than filtering excess DE from the water. I assume you are running the pump 24/7? Are all your test kits strips? If you have a drop based (titration) kit, that will probably get you by for now.
    May 2014
    Plano, TX
    Also, if PoolDoc or one of the others does advise a flocculant later, maybe they can offer a good choice brands. Waiting a day at this point isn't going to make much difference, and it is much easier to add something tomorrow, than to remove something you shouldn't have added today. POP means Pool Owner Patience - that's a term that I learned here. I've often heard that lack of POP is one of the biggest problems pools have.
    Jul 2011
    Los Angeles, CA
    OK, thanks. The test kits are 2 drop, 1 strip.
    And no, it's not on all the time. I ran it that way for 3 or 4 days and saw no change.
    DE filter
    May 2014
    Plano, TX
    Running 24/7 will clear up the excess DE faster, and you'll have to clean it more often. Have you tested chlorine and ph levels with a drops kit? Do you know what your CYA level is? I was under the impression that DE filters "like" to be run constantly to keep the from dropping off the grids. BUT again, I'm not the DE filter expert.
    Jul 2011
    Los Angeles, CA
    Yes, I've tested with the drops kit, and I'm good on chlorine levels. CYA is hard to tell, but might be a bit low.
    Many thanks for your help.
    DE filter
    Jul 2011
    Los Angeles, CA
    BTW - if anyone cares, this problem has been going on for two months now, but until yesterday, and for the longest time, I was unable to get into this site.
    It takes an inordinate amount of my time, and has my wife saying, Let's just drain the pool and leave it empty.
    DE filter
