Running 24/7 will clear up the excess DE faster, and you'll have to clean it more often. Have you tested chlorine and ph levels with a drops kit? Do you know what your CYA level is? I was under the impression that DE filters "like" to be run constantly to keep the from dropping off the grids. BUT again, I'm not the DE filter expert.
