Results 1 to 10 of 47
Thread: Too much DE in pool
    Jul 2011
    Los Angeles, CA
    Default Re: Too much DE in pool
    Right, I have algae NOW, but a few weeks ago I had the same problem and it wasn't green. I've taken the filter apart twice since the problem began, inspected all the grids, and they're fine. But of course, you're right - I must have a filter problem.
    But my original question was: how do I get the DE out of the pool?
    20,000 gallon plaster (concrete) pool
    DE filter
    Nature 2 (unchanged)
    Jul 2011
    Los Angeles, CA
    Oh, and I know it's DE because, when I vacuum the pool, there's an excessive amount of DE in the leaf trap.
    DE filter
    So . . . fix your filter.
    Jul 2011
    Los Angeles, CA
    If I could find what's wrong with it, it would have been fixed months ago. Are you saying that it will then filter the DE? That that's how I get it out of the pool?
    DE filter
    Jul 2011
    Los Angeles, CA
    I know that the filter has a leak - I've been looking for the source of it for about 3 years. But it's not any worse than it was, and this incident happened some time in March.
    DE filter
    I'm not talking about a water leak. DE will not pass through a functioning DE filter.
    In fact, it won't even pass a functioning sand or cartridge filter ( though it can DAMAGE cartridges!). I've actually used that fact for years to test sand filters.
    Jul 2011
    Los Angeles, CA
    Ah, OK, thanks.
    Well, I can take it apart again, the 3rd time, and see if I spy anything. But I'm pretty sure it would have turned up before.
    DE filter
