Results 1 to 10 of 47
Thread: Too much DE in pool
    Feb 2012
    Plano, TX
    Default Re: Too much DE in pool
    Let's try this again.
    Reopening an old wound.
    August 2018 I had a new FNS Plus filter installed by a professional. Evetything ran great for a few months. Then I back washed and I suddenly lost pressure. When I added DE, it immediately came out the returns. Cold weather was coming, so I let it slide.
    Trying to clean up the pool for summer, I opened the filter and saw the manifold was cracked really bad. That explains the pressure loss. I replaced the manifold and put it back together. Pressure shot up to 35 psi (should be about 10). I added DE and out it comes from the returns. A few minutes later my Kreepy Krauly stopped working.
    Any thoughts or suggestions? I assumed once I fixed the filter, I'd run the system for 48 hours with a couple backwashes and it'd be clear again. So much for assumptions.
    Right now the water is vivid green with algae slush and DE all over the bottom and steps. The wife is not happy (believe it or not!!)
    160,000 gallon concrete pool
    FNS Plus DE filter
    Feb 2012
    Plano, TX
    16,000 gallon pool, not 160,000. (couldn't figure out how to edit the original message)
    Virginia
    Just a wild guess, but with a green pool I’d expect a DE filter to clog real fast. Maybe it clogged and a grid ruptured from the high pressure?
    Feb 2012
    Plano, TX
    Real fast I could understand, but immediately??
