Thread: newbie question
    Default newbie question
    Ok just switching to the BBB method,
    todays results:
    fc - 1.0
    ph - 7.5
    alk - 120
    cya - 60
    We have the pool aerating with a fountain hooked up to the return jets to increas the ph a little (it was 6.8)
    so am I right in assuming that I need to up the fc (based on Bens chart)? That it needs to be minimum 5ppm?
    thanks for any advice
    Di
    Pool details: 10,000 gallon inground concrete pool; Full California Sun! DE filtered
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    Default Re: newbie question
    Hi poolgal,
    Looks like everything is in range except the CL being low for 60 cya, so yep add some more to get it up to 5 -10 ppm ... I could live with those numbers , and just float the summer away
