Re: Couple more sand filter questions.
PoolDoc
That is actually what I am replacing. The filter valve needs a new gasket, the extents will need looked at (lots of sand in pool) The positional sticker on the valve is faded, falling apart mostly illegable.
I have replaced the gaskets before, not really a hard job. I suspect this will be more than just a gasket replace as the adjustment lever does not return to seat. A spring is my guess.
How long can the pool go without any filter (while I work on the old one) before I lose ballance?
24 round 12.9K* gal AG vinyl pool; liquide chlorine; sand filter; 2 1 speed pump; 8 hrs; ; the recommended Taylor kit; utility water; summer: solar; winter: mesh; android phone; PF:9.3
