Hi, Don,
That's a pretty easy one. You simply cannot buy a filter too large for your pool or pump....bigger is better.
Since you've got a good grasp on flow rates, capacities, etc., the easiest way to select a new filter would be to calculate your pump gpm first.
Once you get that ( from the manufacturer's info), then look at filters that are rated say around 25% higher than that. So, if your pump gpm is around 60gpm, chose a filter that is at least 75 or so.
I have not seen a sand filter without laterals.......my thinking would be similar to yours. Perhaps the Doughboy folks would be helpful with some technical info.
