Thread: Liner nightmare -> mismeasured pool?
    Default Re: New guy
    Let me see if I understand?
    1. Your receipt says you have a 12 x 24 x 52?
    2. The liner being shipped is 12 x 24 x 52?
    3. You measured 15 x 22 x 52?
    Hmm. The total perimeter on a 15 x 22 is 74'. The total perimeter on a 12 x 24 is 72'. Given that the ends are NOT actually rectangular (which my calculations assumed) that could be the SAME actual perimeter. Is it possible that your 12 x 24 was installed a bit woppy, and ended up a 15 x 22, roughly?
    My recommendation? Call the original seller, the liner maker, and the installer and ask if it's possible you that you have a slightly mis-installed pool. If so, you may be able to make the liner fit. If they say no, beg for mercy and a refund from the liner maker. A 12x24 liner is probably NOT a custom liner, so they could take it back if they are willing. Tell them you'll accept a 60% refund -- but try to catch them BEFORE it ships.
    Good luck!
    Jun 2018
    NY
    Default Re: New guy
    Thanks.
    No dice on the return, I'm hoping I can jostle the posts around and "shrink" it a bit...
    Default Re: New guy
    Good luck!
  1. Pool opening nightmare
    By rtpatter in forum In-Ground Pool Construction and Repair
    Last Post: 03-22-2010, 09:57 AM
  2. Every Pool Owner's Worst Nightmare
    By elsie in forum General Interest
    Last Post: 09-12-2008, 11:00 AM
  3. HELP! Above ground pool nightmare!
    By mmstampa in forum Above-Ground Pool Construction & Repair
    Last Post: 07-29-2006, 12:56 AM
  4. AG pool company nightmare
    By kaydee in forum In-Ground Pool Construction and Repair
    Last Post: 06-16-2006, 02:21 AM
  5. Hayward S220T question and new pool owner nightmare story
    By The Raddish in forum Pool Equipment & Operations
    Last Post: 04-16-2006, 12:22 PM
