Thread: How much liquid pool shock should I use in a 12k gal pool??
    Jun 2018
    Indiana
    Default How much liquid pool shock should I use in a 12k gal pool??
    The liquid pool shock I purchased is 10% sodium hypochlorite. Label on it reads: "Every seven days, or as necessary, superchlorinate the pool with 54 to 108 oz. of this product for each 10,000 gallons of water to yield 5 to 10 ppm available chlorine by weight.
    My pool has 12,500 gallons of water. How many ounces should I use? Thanks.
    Default Re: How much liquid pool shock should I use?
    ________________________________________
    12,500 gallons => 9.6 PF
    10% shock => approx 0.8 lbs chlorine (gas equivalent)
    0.8 x 9.6 = 7.7 ppm
    By the way, "shock" is not a thing, just an action. "Shocking" just means adding more chlorine than usual . . . and there's no magic number.
    Well, there is, but it's not a SINGLE number.
    Rather you should maintain your chlorine level at 5% of whatever your stabilizer level is. So, if CYA=30 ppm, then FC should be 1.5 ppm AND if CYA= 80 ppm, then FC should be 4 ppm
    "Shocking" -- as an action, rather than a chemical -- will help kill off algae and slime that may be getting started in corners, etc. In CLEAR water, with no problems, a weekly dose of 15% of CYA is a good idea (5 ppm if CYA=30; 12 ppm if CYA = 80).
    AND . . . if you add it in the evening, you'll get much more 'bang for your buck'.
    PS. At many Walmart stores you can buy 10% "Pool Essentials Chlorinating Liquid" for $3.27. And it's probably fresher than what the pool store has!
    Jun 2018
    Indiana
    12,500 gallons=>9.6 PF
    0.8 x 9.6 = 7.7 ppm
    2 questions:
    1. What is PF?
    2. Is 7.7 ppm the chlorine that the 1 gallon of 10% sodium hypochlorite will add to my 12,500 gallon pool?
    Quote Originally Posted by Booter View Post
    2 questions:
    1. What is PF?
    1. PF is the ratio between your pool and a pool with 1,000,000 lbs of water (~120,000 gallons). The calculation of the dose effect on a pool is:
      PF x %Concentration x Pounds
    2. Yes. 1 gallon of 10% bleach is ~ 0.8 lbs of 100% chlorine equivalent, and will add 7.7 ppm of chlorine to a pool with a PF of 9.6.
    For example, with 2 lbs of dichlor, the calc would be
    9.6 x 55% x 2 = 10.5 ppm FC
    . . . and . . .
    9.6 x 50% x 2 = 9.6 ppm CYA
  1. New To Site: Question About Shock Powder switching to Liquid Shock
    By mishont in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-15-2014, 07:28 PM
  2. How much liquid chlorine to shock pool
    By ghostcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-28-2013, 12:45 PM
  3. Replies: 5
    Last Post: 05-23-2012, 03:17 PM
  4. Liquid shock, bleach, liquid chlorine?
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 01:26 PM
  5. Liquid Shock??
    By savdoc2 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-24-2006, 10:37 PM
