Thread: Intex Pool Problem
    Jun 2018
    PA
    Default Intex Pool Problem
    I have an above ground Intex pool. I am having trouble with the 2 things that install thru the pool and connect to the pump. I don't know the proper name.
    I think I have them hooked up wrong as when I place my hand over them nothing pushing out of them like last year. Yes the pump is fine. I think I installed them the wrong way. I will have to drain the freekin pool a lot to fix this now. How can I tell which one goes on what side? As I face the pool which one goes in left and which in the right hole?
    Thanks.
    Default Re: Intex Pool Problem
    Sorry, but I'm not sure what you are talking about. You can take some pictures with your phone, and post them with Imgur. This page explains how: http://www.poolforum.com/pf2/showthread.php/29084
    Meanwhile, you can keep your pool from 'going green' by pouring PLAIN bleach or 'liquid pool chlorine' in. 1 gallon of PLAIN bleach will add about 12 ppm of chlorine to a 10,000 gallon pool.
    Walmart is the most consistent source:
    10% Pool-Essentials-Chlorinating-Liquid
    6% Great-Value-Cleaning-Bleach-128-fl-oz/
    [ Upgraded membership; moved thread to "Intex-type" section <= you may need to log out and back in, before you can see everything.
    BTW, if everything is hooked up like it was last year, and is NOT working, then something probably wrong IS with the filter (stopped up cartridge), hoses (mud dauber nest filling them), or pump.
    Just sayin'
  1. Intex Sand Filter Problem- i vacuum dead algea from pool floor & it keeps coming back
    By polockma in forum Intex-type Pool Setup & Operations
    Last Post: 08-05-2012, 05:02 PM
  2. Problem Pool
    By jstkiddn in forum Dealing with Algae & Slime
    Last Post: 06-27-2011, 11:08 AM
  3. intex plastic pool/wall fitting problem...
    By Bowfin in forum Above-Ground Pool Construction & Repair
    Last Post: 08-14-2006, 09:29 PM
  4. Algae problem or fliter problem ?
    By ROBIN13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 03:29 PM
