Thread: Jandy APURE35 Low Temp/Check Salt
    Jun 2018
    Florida
    Default Jandy APURE35 Low Temp/Check Salt
    Indicator is on when salt is 4000 ppm and temp is 80 Deg and CL is 4.0, Is cell working properly?
    Cell is clean, power is normal.
    Default Re: Jandy APURE35 Low Temp/Check Salt
    Sorry, I don't know. Here's the manual:
    https://www.jandy.com/~/media/zodiac...h/h0331400.pdf
    Oct 2011
    North Texas
    Can you post a pic of the system board?
    20'x40' rectangle 34K gal IG concrete pool; SWCG; Jandy DEL60 DE filter; pump; hrs; ; utility water; summer: none; winter: none; ; PF:3.5
    Picture posting instructions: http://pool9.net/postpix/
  1. Jandy Check Valve rusted spring
    By michaelfl in forum Pool Equipment & Operations
    Last Post: 06-14-2014, 11:21 PM
  2. Water temp to add salt?
    By Mr.Mooks in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-30-2012, 06:15 PM
  3. Jandy LRZ "Check IGN Control"
    By nowazzu in forum Pool Equipment & Operations
    Last Post: 04-10-2012, 04:41 PM
  4. bad temp sensor, improved air temp?
    By rmeden in forum Pool Equipment & Operations
    Last Post: 05-29-2009, 10:01 AM
  5. Question on Jandy 90 degree check valve.
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-06-2007, 07:46 PM
