Results 1 to 4 of 4
Thread: Back wash
    Barry J is offline Registered+ Thread Analyst Barry J 0
    Default Back wash
    I have an above ground pool with a sand filter, I noticed that when on “filter” setting that there is water coming from the “backwash” valve outlet
    Any suggestions
    Thanks Barry
    Pappy is offline PF Supporter Widget Weaver Pappy 0
    May 2014
    Plano, TX
    Default Re: Back wash
    I don't have your answer, but if you post the valve brand and model number, you have a much better chance of getting a useful answer. Posting detailed might help too.
    http://www.poolforum.com/pf2/showthr...oolForum-(2018) tells how to post pics.
    Intex 15ftx4ft 4500 gal. 3/4 HP Pentair WhisperFlo pump. Hayward 21" sand filter. Taylor K-2006 & K-1106 kits. PF=27
    It is a Jacuzzi L190 sand filter , the valve is part number 39-2628-03 7 position dial valve
    May 2014
    Plano, TX
    I'm not familiar with that filter, but here's a link to the manual.
    https://www.psposeidon.com/uploads/l...0123132955.pdf
    Seems to suggest a bad o-ring. Sorry I can't help more, maybe someone else can.
