Thread: Problems with scale build-up on Arizona pool
    Jun 2018
    Default Problems with scale build-up on Arizona pool
    what is the best chemical to add weekly to help prevent calcium buildup
    Default Re: hello from arizona
    You're in Arizona . . . you can't assume it's calcium, unless you've tested with acid, and determined that acid will (1) make it fizz and (2) make it come off.
    There are a bunch of places in the Southwest with some pretty nasty water supplies. It doesn't seem to hurt people, but it's hard on pools. Magnesium, silica, and more.
    Are you sure it's calcium? Have you tested your water -- strips don't count -- with a K2006 or something equally reliable?
    If you want to post pictures, check the instructions at http://pool9.net/postpix/
    [ Upgraded membership; moved thread to "Pool Water Problems" section <= you may need to log out and back in, before you can see everything.
  1. Arizona pool with cracks and stains.
    By Scotsman in forum Pool Equipment & Operations
    Last Post: 05-31-2014, 07:53 AM
  2. New IG pool owner in Arizona
    By AZwolverine in forum Pool Equipment & Operations
    Last Post: 03-24-2014, 01:14 PM
  3. Pool Service in Arizona
    By ScottsdaleSwim in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-23-2007, 12:48 AM
  4. Scale build up on DiamondBrite
    By Slam Pool Guy in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-06-2006, 01:27 PM
  5. Calcium/Scale build up on opening
    By DM in forum Dealing with Alkalinity and Calcium
    Last Post: 05-11-2006, 06:17 PM
