Thread: Question Re: Disassembly of Hayward EC-40 Filter to Replace Check Valve
    May 2013
    Northeastern US
    Default Question Re: Disassembly of Hayward EC-40 Filter to Replace Check Valve
    How does this valve come out? From inside the pump? And what tabs do you squeeze, bend, push on, etc, etc to remove the cuff that the check valve sits in? Do you need to remove the intake pipe? Thank you in advance.
    Default Re: Question Re: Disassembly of Hayward EC-40 Filter to Replace Check Valve
    Looks like maybe this video answers: https://www.youtube.com/watch?v=jDYK695_Mc0
    May 2013
    Northeastern US
    That guy is brain dead. I know for a fact that the check valve ass'y comes out into the filter. I've done it before with a differently engineered part. Once you're inside the filter, just pull on that ass'y. Problem is I don't know which tab to push and which way to push it. Thanks for answering up. Jake
    Sorry, but I've never worked on a Perflex myself. Other than the StaRite System 3 DE filter, all the DE filters I've worked on have been large commercial vacuum DE filters, which are completely unlike consumer pressure filters.
  1. Bad Hayward Check Valve EC65 DE=Help to change
    By gfritz1 in forum Pool Equipment & Operations
    Last Post: 05-24-2015, 08:14 PM
  2. Check valve question
    By Rockman59 in forum Pool Equipment & Operations
    Last Post: 06-19-2014, 02:56 PM
  3. Hayward SP 712 Valve, rebuild or replace?
    By glockshooter in forum Pool Equipment & Operations
    Last Post: 06-11-2014, 12:57 AM
  4. Replace filter air relieve valve screen?
    By polyvue in forum Pool Equipment & Operations
    Last Post: 05-14-2010, 05:49 AM
  5. Question on Jandy 90 degree check valve.
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-06-2007, 07:46 PM
