Thread: Lime green water in Illinois in-ground pool
    Default Re: Lime green pool water
    Quote Originally Posted by Ronell View Post
    Is there anything I can do immediately so we can swim? Or begin to clean this mess up?
    Yes! #1 above. Go to the Elgin Walmart and get the bleach and the quick kit. Read the instructions carefully . . . 2x . . . then test the pool and report the results.
    Do NOT let your 'guy' floc the pool: floccing is uncertain at best, and NEVER works on live (= green) algae!
    PS. You will STILL need the kits from Amazon. You can NOT trust your pool guy's testing!
    May 2011
    Southeast Massachusetts
    So glad to see you back on again Pool Doc. Thanks so much for the time, effort and energy. I'm grateful you for all your work here. I found this site when I moved to a new house with an above ground pool and the info I learned has kept my pool in great shape for nine years now. I even replaced my own liner following many posts on here ( and some you tube vids)...
    Anyhow...a phrase I remember well is POP...pool owner patience. Practice it and you will be rewarded eventually. Add the Chlorine as instructed and run the pump continuously. It may take a week or longer but eventually your pool will be clear.
    15,000 Gallon AG -24' round -- Vinyl Liner -- 1 HP Hayward Power Flow LX -- Sand Filter -- PF=5.5
