Thread: Can I use CYA Instead of Dichlor
    Jun 2018
    Delaware
    Default Can I use CYA Instead of Dichlor
    Hi,
    Thanks for all the info here!
    I bought an Intex Easy Set 12 X 20 last spring and made out fine. I will spare you the sob story of how this year has went. I just bought an HTH 6 way kit and the results were ugly. Given my CYA reading was triple the recommended I decided to drain it and start fresh.
    I already have 4 gallons of 6.00% bleach on hand and enough of the stabilizer linked below on to bring the CYA up to the proper level.
    That brings me to my title question - do I still need to use Dichlor or can I use the bleach and stabilizer I already have?
    Stabilizer (label says 100% CYA and no other ingredients are listed): https://www.walmart.com/ip/Clorox-Po...4-lbs/41466055
    Thanks - Herb
    Default Re: Can I use CYA Instead of Dichlor
    Absolutely. Use what you've got.
    The best way I've heard of to dissolve CYA in an intex is to put it in an old sock,and hang it in front of the return.
    By the way, if you happen to end up with high CYA again . . . you can compensate easily, if you have the K2006 kit. You STILL just need to run chlorine at 5% of your CYA, so if it's 120, your normal chlorine level would be 6 ppm.
    By the way, assuming you have the 12 x 20 oval, which is about 4,500 gallons, your PF is 26, so a gallon of bleach would add:
    6% bleach: 26 x 0.06 x 8.4 lbs = 13 ppm of chlorine to your pool
    10% bleach: 26 x 0.10 x 8.5 lbs = 22 ppm of chlorine to your pool.
    Since the 10% Walmart pool bleach has about the same price as the 6%, you might want to get it at Walmart, instead.
    Good luck!
    Jun 2018
    Delaware
    Thanks for the reply.
    Quote Originally Posted by PoolDoc View Post
    your PF is 26!
    What is PF? I looked at the abbreviations thread but that isn't listed.
    Thanks again!
    Is there an abbreviations list I haven't found and updated?
    Anyhow, from the updated list (http://www.poolforum.com/pf2/showthread.php/28985),
    PF => pool factor.
    A 120,000 gallon pool has a PF of 1, so adding 1 lb of CYA will add 1 ppm CYA CYA. A 12,000 gallon pool has a PF of 10, so adding 1 lb of cyanuric add will result in 10 ppm CYA
    Jun 2018
    Delaware
    This is the one I stumbled onto: http://www.poolforum.com/pf2/showthr...eviations-2012
    Thanks. I've now edited THREE (!) old abbreviations lists to refer to the current one!
    . . . Now I need to add a link in each section FAQ . . .
  1. Hello. Question regarding dichlor
    By acrolect in forum General Interest
    Last Post: 06-09-2014, 01:39 PM
  2. New Member with dichlor question
    By azpkumom in forum General Interest
    Last Post: 07-25-2013, 07:33 PM
  3. DiChlor OverKill
    By Stanziaa in forum Pool Chemistry for Intex-type Pools
    Last Post: 09-10-2012, 10:17 PM
  4. Why is dichlor not recommended?
    By Farmingtonpool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-23-2012, 03:05 PM
  5. Dichlor/trichlor????
    By lynnybug55 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-19-2006, 01:22 AM
