Sorry, but I've never worked with Compool equipment.
Like most forums, the PoolForum has discouraged cross posting, but in this case you probably want to try posting to two other forums, TFP and PoolSpaforum. In the past, PSF had the highest proportion of pool industry members, so you might want to start there.
Before you do, I'd recommend using my Super Search page (http://pool9.net/ssearch). It will NOT search directly, but allows you to create custom Google search links that search a single website, including TFP, PSF, and Pentair. It's much easier to find obscure information with a focused search like that.
One caution: Google tends to interpret repeated searches with the 'advanced search operators' as a hacker activity. So if you use the SSearch page links more than 8 or 9 times, give it a break for an hour or so before continuing.
Good luck!
