Results 1 to 3 of 3
Thread: No lights on my SWCG system
    Jun 2013
    Default No lights on my SWCG system
    So frustrating...We have a Saniclear 40 SWAG. Of course it is 3 months out of warranty! When you turn the system on after just a few minutes all of the lights go out...nothing blinking, no power light. Can the flow sensor cause the entire system to shut down...even power? I have replaced the fuse, the cel is fine, salt in the pool is good as well as all chemistry. We have a whole house surge protector so I don't think it would be that. Any thoughts much appreciated. I called the local rep. and he said he was checking on it but haven't heard back from him...guess I'm impatient, but I don't want the pool to turn green!
    PF=5; 23K gal IG kidney vinyl pool, Triton II Sand Filter, Whisperflow VS Pump, Taylor 2006 kit, Jacuzzi/Carvin Saniclear 40 SWCG
    Default Re: No lights on my SWCG system
    From http://www.carvinpool.com/gpc/_media...94180120-3.pdf
    The “Power” LED light is OFF
    + Verify the 20 amp ATO fuse located in the circuit board above the cell connector.
    + Check to make sure the power is connected to the control. Be sure the jumpers are set properly.
    + Verify the voltage with a voltmeter and if the input power is functional the problem could be that the circuit breaker could be tripped.
    + Be sure the jumpers are set properly.
    Did you verify voltage AT the unit ?
    More than that, I can't help with the SWCG. Sorry!
    But . . . regarding 'no green', no problem. Head on over to the Walmart at 12182 Highway 92 . . . and get 10 gallons of "Pool Essentials Chlorinating Liquid" from aisle I.30 (maybe, L.30?). That is fresh 10% chlorine bleach.
    Your pool has a PF of 5, so each gallon will add about 4 ppm of chlorine. Ideally, pour it in as needed, each evening after 7:30 PM (or, not long b4 sunset)
    • If you have no algae, your chlorine level should be at 5% of your stabilizer level, but at least 2 ppm.
    • If you have any sign of algae, FC should be 10% of CYA or higher.
    PS. How did you end up with a rare Canadian SWCG, all the way down in Georgia?
    Jun 2013
    Thanks for the reply. Keeping the bleach in.
  1. intex ultra frame 12x24x52 sand filter swcg system
    By rmills in forum Pool Equipment & Operations
    Last Post: 03-19-2014, 10:53 AM
  2. Bromine Pool vs salt water system (SWCG)
    By Easypare in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-07-2014, 01:36 PM
  3. What SWCG system?
    By sabres07 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-28-2012, 04:54 PM
  4. SWCG versus Ozone/Chlorine system
    By keschete in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-26-2011, 12:30 PM
