Results 1 to 10 of 11
Thread: help newbie
    duraleigh Guest
    Default Re: help newbie
    Hi, Hanna,
    Thanks for the numbers...it appears you did them just right.
    You can get your pool clear with Clorox..you won't require anything else but you'll probably need quite a bit of it.
    1. Download mwsmith2's bleachcalc from any of his posts. Put it on your desktop...you'll use it all Summer.
    1a. Run your pump 24/7 during the process below.
    2. Using the bleachcalc, put in enough Clorox to bring your Cl up to 20-22ppm for your first dose. Measure and calculate accurately.
    3. Test for Cl as often as you can and each time you do, add enough to bring it back up to 20ppm. So if you test 6ppm, add 14ppm to bring the total to 20ppm. Keep doing this as frequently as you can (two or three times daily is good....testing and adding when the Sun is down is even better.) until your water stops showing signs of algae...it may take a few days.
    4. You may need to backwash your filter frequently....particularly the first day. Do it when the pressure rises more than 5psi or so from it's normal range.
    5. Once your water looks like you want it and you have no indication of algae, Stop adding Cl and let it drift down to about 5-6ppm.
    6. Once it gets down to 5-6, you must keep it between 5 -10ppm all the time and your algae issues will be over.
    Post back with questions. Your sand is fine....don't mess with it unless you have some other reason than algae to think you have a filter problem. This whole process may take a few days....be patient and keep adding Cl.
    hannadock Guest
    Thanks. I am going to change out the sand this week. It's overdue. Need a new gauge as well. What is the difference between Super Shock and Bleach?
    hannadock Guest
    Sorry missed the part about the sand. It is well over 10 years old. I may hold off and see how everything goes based on your response. thanks again
    duraleigh Guest
    Hanna,
    Good catch on the sand. The same water that kills the junk in your pool circulates over and over in your filter as well...killing anything in there. It's probably not a bad idea to open the lid of the filter and see if you have enough in there (usually about 2/3 to 3/4 full) and to check the general condition but, unless you see something obviously wrong, that sand will last another 10 years or more.
    "Super Shock" is a brand name probably for Cal Hypo. It and Bleach are simply different forms of chlorine. The Cal Hypo adds calcium to your pool which you do not need in a vinyl pool.
    hannadock Guest
    My water is clear now and all my numbers look good except today my ph is low. Is it ok to add my borax 20 mule? thanks
    duraleigh Guest
    HANNA,
    Borax now is no problem. When you get a chance, post a set of current test results so we can see where you are. Good work
    hannadock Guest
    Talking Re: help newbie
    here are my new readings
    stabilizer 110
    alk 40
    ph 7.6
    fc 1.0
    tc 1.5
    it rained terribly Friday night. I have not put any bleach in today. is it normal for your stabilizer to raise with Borax. it was lower before I did.
    thanks
