Sorry missed the part about the sand. It is well over 10 years old. I may hold off and see how everything goes based on your response. thanks again
Hanna,
Good catch on the sand. The same water that kills the junk in your pool circulates over and over in your filter as well...killing anything in there. It's probably not a bad idea to open the lid of the filter and see if you have enough in there (usually about 2/3 to 3/4 full) and to check the general condition but, unless you see something obviously wrong, that sand will last another 10 years or more.
"Super Shock" is a brand name probably for Cal Hypo. It and Bleach are simply different forms of chlorine. The Cal Hypo adds calcium to your pool which you do not need in a vinyl pool.
My water is clear now and all my numbers look good except today my ph is low. Is it ok to add my borax 20 mule? thanks
HANNA,
Borax now is no problem. When you get a chance, post a set of current test results so we can see where you are. Good work![]()
here are my new readings
stabilizer 110
alk 40
ph 7.6
fc 1.0
tc 1.5
it rained terribly Friday night. I have not put any bleach in today. is it normal for your stabilizer to raise with Borax. it was lower before I did.
thanks
Hanna,
You are testing or typing inaccurately.
Recheck results for Alk.
Your CYA should not have moved hardly at all unless you've added CYA...recheck your results.
from an earlier post:
Given your Cl of 1.0 you are asking for the algae to return.6. Once it gets down to 5-6, you must keep it between 5 -10ppm all the time and your algae issues will be over.
