My water is clear now and all my numbers look good except today my ph is low. Is it ok to add my borax 20 mule? thanks
HANNA,
Borax now is no problem. When you get a chance, post a set of current test results so we can see where you are. Good work![]()
here are my new readings
stabilizer 110
alk 40
ph 7.6
fc 1.0
tc 1.5
it rained terribly Friday night. I have not put any bleach in today. is it normal for your stabilizer to raise with Borax. it was lower before I did.
thanks
Hanna,
You are testing or typing inaccurately.
Recheck results for Alk.
Your CYA should not have moved hardly at all unless you've added CYA...recheck your results.
from an earlier post:
Given your Cl of 1.0 you are asking for the algae to return.6. Once it gets down to 5-6, you must keep it between 5 -10ppm all the time and your algae issues will be over.
